Configure the Fast Advertisement Interval to send VRRP advertisement
messages. The interval can be between 200 and 1000 milliseconds, and
it must be the same on all participating routers. The default is 200.
Enter the values in multiples of 200 milliseconds.
- In the navigation pane,
expand the following folders: .
 - Click .
 - Select a VLAN.
 - Click IP.
 - Click the VRRP tab.
 - Click Insert.
 - In the IP, VLAN, Insert
VRRP dialog box, click the FasterAdvIntervalEnable enable option.
 - In the FasterAdvInterval, box, enter a value. You must set the value using multiples of 200
milliseconds.
 - Click Insert.
