Assign an IPv6 address to a VLAN.
 - Click VLANs.
 - Click the Basic tab.
 - Select a VLAN interface.
 - Click IPv6.
 - Click the IPv6 Addresses tab.
 - Click Insert.
 - Type the IPv6 address and length in the fields.
 - Click Insert.
 - Click Apply.
IPv6 Addresses field descriptions
Use the data in the following table to use the IPv6 Addresses tab.
 Name  |
 Description  |
 Interface  |
 Identifies the address to which the address is assigned.  |
 Addr  |
 Specifies an IP address that is associated with a VLAN.  |
 AddrLen  |
 Specifies the prefix address length value for this address.  |
 Type  |
 Specifies the type of address: either unicast or anycast.  |
 Origin  |
 Specifies the origin of the address as one of the following:
 Status  |
 Shows the status of the address and if it can be used for communication.  |
 Created  |
 Shows the time this address entry was created.  |
 LastChanged  |
 Shows the time this address entry was last updated.  |
