View information about OSPF to view the current configuration.
Switch:1#show ipv6 ospf
                       OSPFv3 Global Information - GlobalRouter
        router-id                      : 170.76.84.0
        admin-state                    : DISABLE
        version                        : 3
        area-bdr-rtr-state             : FALSE
        as-bdr-rtr-state               : FALSE
        helper-mode                    : ENABLED
        as-scope-lsa-count             : 0
        lsa-checksum                   : 0
        originate-new-lsas             : 0
        rx-new-lsas                    : 0
        ext-lsa-count                  : 0
              default-metric :
                         ethernet - 100
                    fast-ethernet - 10
                     gig-ethernet - 1
                 ten-gig-ethernet - 1
               forty-gig-ethernet - 1
                             vlan - 10
                        Switch:1>show ipv6 ospf area
                              OSPF Area - GlobalRouter
AREA_ID         STUB_AREA  NSSA  IMPORT_SUM TRANS_ROLE TRANS_STATE
0.0.0.0         false      false true       always     disabled
STUB_METRIC STUB_METRIC_TYPE SPF_RUNS BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT LSACK_SUM
10          ospfV3Metric     0        0           0             0       0
                        Switch:1#show ipv6 ospf interface
Total ospf areas: 1
Total ospf interfaces: 2
                         OSPF Interface - GlobalRouter
IFINDX(VID/BRT/CLIP) AREAID          ADM IFSTATE  METRIC PRI DR/BDR          IFTYPE
192   (BRT-1/1     ) 0.0.0.0         dis DOWN     0      1   0.0.0.0         BROADCAST
                                                            0.0.0.0
1353  (CLIP-10     ) 0.0.0.0         ena LOOPBACK 0      1   0.0.0.0         PASSIVE
                                                            0.0.0.0
2148  (VID-100     ) 0.0.0.0         ena DOWN     10     1   0.0.0.0         BROADCAST
3 out of 3 Total Num of ospf interfaces displayed
Total ospf virtual interfaces: 0
                       OSPF Virtual Interface - GlobalRouter
AREAID          NBRIPADDR       STATE
0 out of 0 Total Num of ospf virtual interfaces displayed
                        Switch:1#show ipv6 ospf int-timers
                       OSPF Interface Timers - GlobalRouter
                                TRANSIT  RETRANS  HELLO    DEAD     POLL
IFINDX(VID/BRT/CLIP) AREAID          DELAY    INTERVAL INTERVAL INTERVAL INTERVAL
2059  (BRT-11          ) 0.0.0.0         1        5        10       40       120
2060  (CLIP-12         ) 0.0.0.0         1        5        10       40       120
                       OSPF Virtual Interface Timers - GlobalRouter
AREAID          NBRIPADDR       DELAY    INTERVAL INTERVAL INTERVAL
                        Switch:1#show ipv6 ospf neighbor
                          OSPF Neighbor - GlobalRouter
IFINDX(VID/BRT) NBRROUTERID     NBRIPADDR                                STATE     TTL
331    (10/19) 97.146.128.0   fe80:0:0:0:2ef4:c5ff:fe92:8a00	Restart	120
1 out of 1 Total Num of Neighbor Entries displayed.
                      OSPF Virtual Neighbor - GlobalRouter
NBRAREAID       NBRROUTERID     VIRTINTFID NBRIPV6ADDR                             STATE
0 out of 0 Total Num of Virtual Neighbor Entries displayed.
                       OSPF NBMA Neighbor - GlobalRouter
INTERFACE NBRROUTERID     NBRIPADDR                                STATE
0 out of 0 Total Num of NBMA Neighbor Entries displayed.
Use the data in the following table to use the show ipv6 ospf lsdb commands.
| Variable | Value |
| adv-rtr <A.B.C.D> | Shows information for the specified advertising router. |
| area <A.B.C.D> | Shows information for the specified area. |
| detail | Shows information beyond the basic information. |
| interface gigabitethernet {slot/port[/sub-port]} | Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| lsa-type <1-11> | Shows information for the specified LSA type. |
| lsid <0-4294967295> | Shows information for the specified link-state ID. |
| scope <1-3> | Shows information for the specified scope:
| tunnel <1-2000> | Specifies the ID number of the tunnel. |
| vrf WORD<1-16> | Specifies the VRF name. |
| vrfids WORD<0-512> | Specifies VRF IDs. |
