Manage the broadcast interface by specifying and displaying which router interfaces can receive UDP broadcasts to forward.
Broadcast Interfaces field descriptions
Use the data in the following table to use the Broadcast Interfaces tab.
| Name | Description |
| LocalIfAddr | Specifies the IP address of the local router interface that receives forwarded UDP broadcast packets. |
| UdpPortFwdListId | Specifies the number of the UDP lists or profiles that this interface is configured to forward (0 to100). A value of 0 indicates that the interface cannot forward any UDP broadcast packets. |
| MaxTtl | Specifies the maximum number of hops an IP broadcast packet can take from the source device to the destination device (the default is 4; the range is 1 to 16). |
| NumRxPkts | Specifies the total number of UDP broadcast packets received by this local interface. |
| NumFwdPkts | Specifies the total number of UDP broadcast packets forwarded by this local interface. |
| NumDropPktsMaxTtlExpired | Specifies the total number of UDP broadcast packets dropped because the time-to-live (TTL) value expired. |
| NumDropPktsDestUnreach | Specifies the total number of UDP broadcast packets dropped because the destination was unreachable. |
| NumDropPktsUnknownPort | Specifies the total number of UDP broadcast packets dropped because the destination port or protocol specified has no matching forwarding policy. |
| BroadCastMask | Specifies the subnet mask of the local interface that broadcasts the UDP broadcast packets. |
