This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB Distributed Virtual Routing (DvR) backbone redistribtuion on the switch.
- Select MultiArea
- Select the DVR Redistribute tab.
- Select DvrBbRedistribute.
- Select Apply.
DVR Redistribute Field Descriptions
Use data in the following table to use the DVR Redistribute tab.
| Name | Description |
| DvrBbRedistribute | Configures the Multi-area SPB DvR redistribution on the switch. The default is disabled. |
