The MKA participant with the highest actor priority is designated as the key server.
Apply an MKA profile to the port.
Disable MKA on the port before you configure a value for actor priority. Enable MKA on the port after you configure an actor priority value.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/4 Switch:1(config-if)#macsec actor-priority 0x0f
The following table defines parameters for the macsec actor-priority command.
Variable |
Value |
<0x00-0xff> |
Specifies a hexadecimal value for actor priority, which determines key server selection. Lower values indicate a higher priority. The default is 10. |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
