The following table defines parameters for the filter acl ace policer command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
<ace-id> |
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
svc-rate <0-4000000000> Note:
Exception: only supported on VSP 4900 Series andVSP 7400 Series. |
Specifies the rate of the traffic committed to be delivered. Service rate limit in kbps {0-4000000000}.The granularity is 8 kbps. |
| peak-rate
<8-4000000000> Note:
Specifies the value when exceeded causes packets to drop on ingress. Peak rate limit in kbps {8-4000000000}.The granularity is 8 kbps. |
