Perform this procedure to display the filter Access Control List (ACL) configuration on the switch.
enable
show filter acl
Switch:1(config)#show filter acl
                                                   Vlan/VSN ACL Table
Acl  Type    AclName             PktType    State    Origin # of      Default   CtrPkt      Service-rate Peak-rate    Vlan/I-sid
Id        ACEs    Action     Rule            Id
                                              Vlan ACL Global-Action Table
Acl  Type    Ipfix       Monitor     Monitor
Id                       Dst-Mlt     Dst-Port
                                                     Port ACL Table
Acl  Type    AclName             PktType    State       Origin   # of      Default   CtrPkt      Service-rate Peak-rate   Port
Id        ACEs    Action     Rule
1    Ingress ACL-1                  nonipv6    enabled  config   2           permit  permit        100               200  1/1
3    Ingress ACL-3                  nonipv6    enabled  config   1           permit  permit        800               1000  1/7-1/8
                                              Port ACL Global-Action Table
Id                       Dst-Mlt     Dst-Port
1    Ingress Disable     0
3    Ingress Disable     0
Displayed 2 of 2 Entries
