Display information about the files in internal flash memory on this device.
- Select File System.
- Select the Flash Files tab.
Flash Files field descriptions
Use the data in the following table to use the Flash Files tab.
Name |
Description |
Slot |
Specifies the slot number. |
Name |
Specifies the directory name of the file. |
Date |
Specifies the creation or modification date of the file. |
Size |
Specifies the size of the file. |
