View BGP global stats.
- Click BGP.
- Click the Global Stats tab.
Global Stats Field Descriptions
Use the data in the following table to use the BGP Global Stats tab.
Name |
Description |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the Stats tab. |
Average/sec |
Displays the average value for each second. |
Minimum/sec |
Displays the minimum value for each second. |
Maximum/sec |
Displays the maximum value for each second. |
LastVal/sec |
Displays the last value for each second. |
Starts |
Displays the number of times the BGP connection started. |
Stops |
Displays the number of times the BGP connection stopped. |
Opens |
Displays the number of times BGP opens TCP. |
Closes |
Displays the number of times BGP closes TCP. |
Fails |
Displays the number of times TCP attempts failed. |
Fatals |
Displays the number of times TCP crashes due to fatal error. |
ConnExps |
Displays the number of times the TCP retry timer expired. |
HoldExps |
Displays the number of times the hold timer expired. |
KeepExps |
Displays the number of times the keepalive timer expired. |
RxOpens |
Displays the number of open instances BGP receives. |
RxKeeps |
Displays the number of keepalive instances BGP receives. |
RxUpdates |
Displays the number of update instances BGP receives. |
RxNotifys |
Displays the number of notification instances BGP receives. |
TxOpens |
Displays the number of open instances BGP transmitted. |
TxKeeps |
Displays the number of keepalive instances BGP transmitted. |
TxUpdates |
Displays the number of updates instances BGP transmits. |
TxNotifys |
Displays the number of notification instances BGP transmits. |
BadEvents |
Displays the number of invalid events FSM received. |
SyncFails |
Displays the number of times FDB sync failed. |
TrEvent |
Displays the trace event. |
RxECodeHeader |
Displays the total header errors received. |
RxECodeOpen |
Displays the total open errors received. |
RxECodeUpdate |
Displays the total update errors received. |
RxECodeHoldtimer |
Displays the total hold timer errors received. |
RxECodeFSM |
Displays the total FSM errors received. |
RxECodeCease |
Displays the total cease errors received. |
RxHdrCodeNoSync |
Displays the header not synchronized errors received. |
RxHdrCodeInvalidMsgLen |
Displays the header invalid message length errors received. |
RxHdrCodeInvalidMsgType |
Displays the header invalid message type errors received. |
RxOpCodeBadVer |
Displays the open errors received for Bad Version. |
RxOpCodeBadAs |
Displays the open errors received for le Bad AS Number. |
RxOpCodeBadRtID |
Displays the open errors received for Bad BGP Rtr ID. |
RxOpCodeUnsuppOption |
Displays the open errors received for Unsupported Option. |
RxOpCodeAuthFail |
Displays the open errors received for Auth Failures. |
RxOpCodeBadHold |
Displays the open errors received for Bad Hold Value. |
RxUpdCodeMalformedAttrList |
Displays the update errors received for Malformed Attr List. |
RxUpdCodeWelKnownAttrUnrecog |
Displays the update errors received for Welknown Attr Unrecog. |
RxUpdCodeWelknownAttrMiss |
Displays the update errors received for Welknown Attr Missing. |
RxUpdCodeAttrFlagError |
Displays the update errors received for Attr Flag Error. |
RxUpdCodeAttrLenError |
Displays the update errors received for Attr Len Error. |
RxUpdCodeBadORIGINAttr |
Displays the update errors received for Bad ORIGIN Attr. |
RxUpdCodeASRoutingLoop |
Displays the update errors received for AS Routing Loop. |
RxUpdCodeBadNHAttr |
Displays the update errors received for Bad NEXT-HOP Attr. |
RxUpdCodeOptionalAttrError |
Displays the update errors received for Optional Attr Error. |
RxUpdCodeBadNetworkField |
Displays the update errors received for Bad Network Field. |
RxUpdCodeMalformedASPath |
Displays the update errors received for Malformed AS Path. |
TxECodeHeader |
Displays the total Header errors transmitted. |
TxECodeOpen |
Displays the total Open errors transmitted. |
TxECodeUpdate |
Displays the total Update errors transmitted. |
TxECodeHoldtimer |
Displays the total Hold timer errors transmitted. |
TxECodeFSM |
Displays the total FSM errors transmitted. |
TxECodeCease |
Displays the total Cease errors transmitted. |
TxHdrCodeNoSync |
Displays the header Not Synchronized errors transmitted. |
TxHdrCodeInvalidMsgLen |
Displays the header Invalid msg len errors transmitted. |
TxHdrCodeInvalidMsgType |
Displays the header Invalid msg type errors transmitted. |
TxOpCodeBadVer |
Displays the open errors transmitted for Bad Version. |
TxOpCodeBadAs |
Displays the open errors transmitted for Bad AS Number. |
TxOpCodeBadRtID |
Displays the open errors transmitted for Bad BGP Rtr ID. |
TxOpCodeUnsuppOption |
Displays the open errors transmitted for Unsupported Option. |
TxOpCodeAuthFail |
Displays the open errors transmitted for Auth Failures. |
TxOpCodeBadHold |
Displays the open errors transmitted for Bad Hold Value. |
TxUpdCodeMalformedAttrList |
Displays the update errors transmitted for Malformed Attr List. |
TxUpdCodeWelknownAttrUnrecog |
Displays the update errors transmitted for Welknown Attr Unrecog. |
TxUpdCodeWelknownAttrMiss |
Displays the update errors transmitted for Welknown Attr Missing. |
TxUpdCodeAttrFlagError |
Displays the update errors transmitted for Attr Flag Error. |
TxUpdCodeAttrLenError |
Displays the update errors transmitted for Attr Len Error. |
TxUpdCodeBadORIGINAttr |
Displays the update errors transmitted for Bad ORIGIN Attr. |
TxUpdCodeASRoutingLoop |
Displays the update errors transmitted for AS Routing Loop |
TxUpdCodeBadNHAttr |
Displays the update errors transmitted for Bad NEXT-HOP Attr |
TxUpdCodeOptionalAttrError |
Displays the update errors transmitted for Optional Attr Error. |
TxUpdCodeBadNetworkField |
Displays the update errors transmitted for Bad Network Field. |
TxUpdCodeMalformedASPath |
Displays the update errors transmitted for Malformed AS Path. |
