Create an SMLT from an existing MLT to split physical ports between two switches to improve resiliency and provide active load sharing.
Create an MLT before you create a split in the MLT.
enable
configure terminal
interface mlt <1-512>
smlt
Important
To create an SMLT from an existing MLT, first shut down the MLT ports. Configure the MLT as SMLT, and then enable the ports again.
Failure to perform this operation can lead to ports in STP blocked state and traffic loss.
Important
If you want to remove SMLT configuration from the MLT on a vIST switch, first shut the SMLT MLT ports on its vIST peer.
Failure to perform this operation can lead to Layer 2 loops.
Important
If you are configuring SMLT with vIST, all the SMLT VLANs associated with vIST must have an I-SID.
Create an SMLT on MLT 1:
Switch:1(config)#interface mlt 1 Switch:1(config-mlt)#smlt
