This procedure does not apply to VSP 8600 Series and XA1400 Series.
Use this procedure to configure the maximum EAP and NEAP MAC clients supported on Auto-sense enabled ports.
If you manually configure values on a specific port(s), then these values will take precedence over the Auto-sense global values.
enable
configure terminal
auto-sense eapol multihost mac-max <1-8192>
Configure a maximum of 10 EAP and NEAP MAC clients supported on Auto-sense enabled ports.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense eapol multihost mac-max 10
