You must first onboard the device and configure any optional IQ Agent parameters before you enable IQ Agent.
- In the navigation pane, expand
- Select IQAgent.
- Select the Globals tab.
- Configure optional parameters as required.
- Select Apply.
- Select Enable.
- Select Apply.
Use the data in the following table to use the Global tab to configure the ExtremeCloud IQ Agent.
Name |
Description |
Enable |
Specifies whether IQ Agent is enabled. The default is enabled. |
Version |
Displays the ExtremeCloud IQ Agent firmware version running on the switch. |
OperStatus |
Displays the operational status of ExtremeCloud IQ Agent on the switch. |
ServerAddressType |
Specifies the address type of the ExtremeCloud IQ server address. |
ServerAddress |
Specifies the ExtremeCloud IQ IPv4 address or DNS name. The default is hac.extremcloudiq.com. |
ServerAddressOrigin |
Specifies the origin for the ExtremeCloud IQ server address:
Address |
Specifies the proxy IPv4 address or DNS name. |
TcpPort |
Specifies the TCP connection port. |
UserName |
Specifies the proxy server password. |
Password |
Specifies the proxy server username. |
AssociationUrl |
Displays the association URL of ExtremeCloud IQ. |
PollUrl |
Displays the poll URL of ExtremeCloud IQ. |
MonitorFreq |
Displays the monitoring frequency, in seconds, of ExtremeCloud IQ. |
PollFreq |
Displays the polling frequency, in seconds, of ExtremeCloud IQ. |
LastOnboardTime |
Displays the last onboard time of ExtremeCloud IQ. |
LastPollStatus |
Displays the last poll status of ExtremeCloud IQ. |
LastPollTime |
Displays the last poll time for a successful attempt. |
LastMonitorStatus |
Displays the last monitoring status of ExtremeCloud IQ. |
LastMonitorTime |
Displays the last monitor time for a successful attempt. |
LastHealthStatus |
Displays the last health status of ExtremeCloud IQ. |
LastHealthTime |
Displays the last health time for a successful attempt. |
LastDisconnectedTime |
Shows when IQ Agent disconnected from ExtremeCloud IQ. This status is not valid unless IQ Agent is enabled and in a disconnected state. |
LastAttemptedAssociationTime |
Shows the last time IQ Agent attempted to associate with ExtremeCloud IQ. This status is not valid unless IQ Agent is enabled and in a disconnected state. |
NextAssociationAttempt |
Shows the next time IQ Agent will attempt to associate with ExtremeCloud IQ. This field displays In progress if IQ Agent is currently attempting to associate. This status is not valid unless IQ Agent is enabled and in a disconnected state. |
AssociationFrequencyMode |
Shows the frequency at which IQ Agent attempts to associate with ExtremeCloud IQ. Fast mode indicates an attempt every 40 seconds. Slow mode indicates an attempt every hour. For the first 24 hours of disconnection, the mode is Fast mode. The mode then changes to slow and remains in slow mode until successfully connected. This status is not valid unless IQ Agent is enabled and in a disconnected state. When you first onboard a device to ExtremeCloud IQ, it does not connect to the device immediately; it waits until the device attempts association again, which can take up to 1 hour. |
