Use the following procedure to display the OVSDB protocol support for VXLAN Gateway configuration.
show ovsdb config
SWITCH:1>show ovsdb config
Ovsdb Config Info
Status - Enabled
Certificate - Installed
Private Key - Installed
Replication Peer NLS-IP - 192.0.2.3
Replication Local NLS-IP - 192.0.2.2
Ovsdb Controller Config Info
ID Protocol IP Port
1 ssl 192.0.2.10 6640
