This procedure only applies to the VSP 7400 Series.
Perform this procedure to view statistical graph of the remote IS-IS interface counters.
 - Select IS-IS Remote.
 - Select the Interfaces tab.
 - Select an interface.
 - Select the Graph button.
Interface Counters Field Descriptions
The following table describes the fields in the Interface Counters tab.
 Name  |
 Description  |
 InitFails  |
 Indicates the number of times initialization of this circuit has failed. This counts events such as PPP NCP failures.  |
 RejAdjs  |
 Indicates the number of times an adjacency has been rejected on this circuit.  |
 IDFieldLenMismatches  |
 Indicates the number of times an Intermediate-System-to-Intermediate-System (IS-IS) control PDU with an ID field length different from that for this system has been received.  |
 MaxAreaAddrMismatches  |
 Indicates the number of times an IS-IS control PDU with a max area address field different from that for this system has been received.  |
 AuthFails  |
 Indicates the number of times an IS-IS control PDU with the correct auth type has failed to pass authentication validation.  |
 LANDesISChanges  |
 Indicates the number of times the Designated IS has changed on this circuit at this level. If the circuit is point to point, this count is zero.  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the Stats tab.  |
 Average/Sec  |
 Displays the average value for each second.  |
 Minimum/Sec  |
 Displays the minimum value for each second.  |
 Maximum/Sec  |
 Displays the maximum value for each second.  |
 Last Val/Sec  |
 Displays the last value for each second.  |
