After your device is onboarded (that is, the serial number for the device is associated with your ExtremeCloud IQ account), you are only required to enable ExtremeCloud IQ Agent. Other feature configuration, such as configuring proxy parameters and configuring access to ExtremeCloud IQ is optional.
You must configure a Segmented Management Instance to use ExtremeCloud IQ Agent. For more information, see Segmented Management Instance Configuration using the CLI.
For information about onboarding switches, see https://www.extremenetworks.com/support/documentation/extremecloud-iq/.
