DEMO FEATURE - Read Only User for EDM is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see Fabric Engine and VOSS Feature Support Matrix.
Perform this procedure to enable the web server RO user, which is disabled by default after a software upgrade.
enable
configure terminal
web-server read-only-user enable
Switch:1>enable Switch:1#configure terminal
Enable the default ro username:
Switch1:(config)#web-server read-only-user enable
Display the output of the show web-server command with the ro username enabled:
Switch:1(config)#show web-server
Web Server Info :
Status : on
Secure-only : enabled
TLS-minimum-version : tlsv12
RO Username Status : enabled
RO Username : jones6
RO Password : ********
RWA Username : smith2
RWA Password : ********
Def-display-rows : 30
Inactivity timeout : 900 sec
Html help tftp source-dir :
HttpPort : 80
HttpsPort : 443
NumHits : 87
NumAccessChecks : 4
NumAccessBlocks : 0
NumRxErrors : 73
NumTxErrors : 0
NumSetRequest : 0
Minimum password length : 8
Last Host Access Blocked : 0.0.0.0
In use certificate : Self signed
