Feature |
Product |
Release introduced |
SLA Mon |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
Not Supported |
5720 Series |
Not Supported |
VSP 4450 Series |
VOSS 4.1 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 6.0 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 4.1 |
VSP 8400 Series |
VOSS 4.2 |
VSP 8600 Series |
VSP 8600 4.5 |
XA1400 Series |
Not Supported |
The switch supports the Service Level Agreement Monitor (SLA Mon) agent as part of the SLA Mon solution.
SLA Mon uses a server and agent relationship to perform end-to-end network Quality of Service (QoS) validation and to distribute monitoring devices. You can use the test results to target under-performing areas of the network for deeper analysis.
