Use this procedure to view the MACsec interface statistics using EDM.
MACsec Interface Stats Field Descriptions
The following table describes the fields in the MACsec Interface Stats tab.
| Field | Description |
| TxUntaggedPkts | Specifies the number of transmitted packets without the MAC security tag (SecTAG), with MACsec disabled on the interface. |
| TxTooLongPkts | Specifies the number of transmitted packets discarded because the packet length is greater than the maximum transmission unit (MTU) of the common port interface. |
| RxUntaggedPkts | Specifies the number of received packets without the MAC security tag (SecTAG), with MACsec not operating in strict mode. |
| RxNoTagPkts | Specifies the number of received packets without the MAC security tag (SecTAG), with MACsec operating in strict mode. |
| RxBadTagPkts | Specifies the number of received packets discarded with an invalid SecTAG, or with a zero value packet number (PN), or invalid Integrity Check Value (ICV). |
| RxUnknownSCIPkts | Specifies the number of packets received with an unknown secure channel identifier (SCI), and with MACsec not operating in strict mode. |
| RxNoSCIPkts | Specifies the number of packets received with an unknown secure channel identifier (SCI), and with MACsec operating in strict mode. |
| RxOverrunPkts | Specifies the number of packets discarded because the number of received packets exceeded the cryptographic performance capabilities. |
