The following considerations apply to Zero Touch Provisioning Plus (ZTP+) :
Fabric configurations are not supported with ZTP+. After ZTP+ is configured, ExtremeCloud IQ ‑ Site Engine server can use Simple Network Management Protocol (SNMP) to remotely configure Fabric-related configurations on the switch using SNMP MIBs.
Only the Out-of-Band (OOB) port or the Management VLAN interface are used to connect the ExtremeCloud IQ ‑ Site Engine server.
ZTP+ cannot change the Management VLAN interface. If onboarding started on the Management onboarding VLAN, this cannot be changed while using ZTP+.
