Use the following procedure to remove a software build for the switch.
A maximum of 6 software releases can be installed on the switch. When the limit is reached, you are prompted to remove one release before you can proceed with adding and activating a new software release.
enable
software remove WORD<1-99>
Remove the software build:
Switch:1>enable Switch:1#software remove w.x.y.z
