The following section provides procedures to configure the DHCP binding table using EDM.
Use the following procedure to add entries for devices with static IP addresses to the DHCP binding table.
 - Click DHCP Snooping.
 - Click the DHCP Bindings tab.
 - Click Insert.
 - In the VlanId field, enter the VLAN ID.
 - In the MacAddress field, enter the MAC address of the DHCP client.
 - In the AddressType field, select a value.
 - In the Address field, enter the IP address of the DHCP client.
 - In the Interface field, select a port.
 - In the LeaseTime(sec) field, enter the time in seconds.
 - Click Insert.
 - Click Apply.
DHCP Bindings field descriptions
Use data in the following table to use the DHCP Bindings tab.
 Name  |
 Description  |
 VlanId  |
 Specifies the VLAN to which the DHCP client belongs.  |
 MacAddress  |
 Specifies the MAC address of the DHCP client.  |
 AddressType  |
 Specifies the type of address. The default address type is IPv4.  |
 Address  |
 Specifies the IP address assigned to the DHCP client.  |
 Interface  |
 Specifies the interface to which the DHCP client connects.  |
 LeaseTime(sec)  |
 Specifies the lease time (in seconds) of the particular DHCP binding entry. The time range is 0 to 2147483646 seconds.  |
 TimeToExpiry(sec)  |
 Species the time of expiry (in seconds) of the DHCP binding entry.  |
 EntryType  |
 Specifies the type of the DHCP binding entry.
Use the following procedure to view all entries in the DHCP binding table.
 Name  |
 Description  |
 VlanId  |
 MacAddress  |
 AddressType  |
 Address  |
 Interface  |
 LeaseTime(sec)  |
 TimeToExpiry(sec)  |
 EntryType  |
