Use the following procedure to display information about all MKA profiles configured on the switch. Optionally, you can view information about a specific MKA profile.
The following example displays MACsec MKA profile information:
Switch:1#show macsec mka profile
MACsec MKA Profile
Profile Profile Cipher Confidentiality Replay Window Port Include-SCI
Name Id Suite Offset Protect Size
test030519 1 gcm-aes-128 30 Enabled 200 1/3 false
test031519 2 gcm-aes-128 50 Enabled 225 1/4 false
test032019 3 gcm-aes-128 30 Enabled 240 2/2 false
All 3 out of 3 Total Num of MACsec MKA Profiles displayed
The following example displays MACsec MKA information for a specific profile.
Switch:1#show macsec mka profile test030519
MACsec MKA Profile
The following table defines parameters for the show macsec mka profile command.
| Variable | Value |
WORD<1-16> |
Specifies the MKA profile name. An MKA profile name can consist only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive. |
