Configure local port Auto-Negotiation advertisements to specify the speed and duplex mode for traffic between local ports and remote link partners. Supported speeds and duplex modes vary, depending on your hardware.
You must enable Auto-Negotiation before you perform this procedure.
Configure local port Auto-Negotiation advertisements.
The following table defines parameters for the auto-negotiation-advertisements command.
Variable |
Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Specifies the port or ports that you want to configure. |
25000-full |
Advertises 25 Gbps full-duplex. |
10000-full |
Advertises 10 Gbps full-duplex. |
5000-full |
Advertises 5 Gbps full-duplex. |
2500-full |
Advertises 2.5 Gbps full-duplex. |
1000-full |
Advertises 1 Gbps full-duplex. |
100-full |
Advertises 100 Mbps full-duplex. |
100-half |
Advertises 100 Mbps half-duplex. |
10-full |
Advertises 10 Mbps full-duplex. |
10-half |
Advertises 10 Mbps half-duplex. |
none |
Configures the Auto-Negotiate value to none. |
