You must enable IP Routing on the interface.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Use the DHCP Relay tab to configure the DHCP behavior on a VLAN. The DHCP Relay tab is available only if the VLAN is routed and is assigned an IP address.
- Select VLANs.
- Select the Basic tab.
- Select a VLAN.
- Select IP.
- Select the DHCP Relay tab.
- Select Enable.
- Optional: Configure the parameters as required.
- Select Apply.
DHCP Relay field descriptions
Use the data in the following table to use the DHCP Relay tab.
Variable |
Value |
Enable |
Lets you use BootP/DHCP on the port. The default is disable. |
MaxHop |
Sets the maximum number of hops a BootP/DHCP packet can take from the DHCP client to the DHCP server. The maximum number of hops is 16. The default is 4. |
MinSec |
Represents the minimum number of seconds to wait between receiving a DHCP packet and forwarding the DHCP packet to the DHCP server. A value of 0 indicates that forwarding is done immediately. The default value is 0. |
Mode |
Indicates the type of DHCP packet required. The options are:
The default is both. |
AlwaysBroadcast |
When enabled, the DHCP Reply packets are sent as a broadcast to the DHCP client. The default is disable. |
CircuitId |
Indicates whether DHCP Relay inserted the option 82 circuit ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable. |
RemoteId |
Indicates whether DHCP Relay inserted the option 82 remote ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable. |
Trusted |
Indicates if DHCP packets come through a trusted DHCP circuit. Only packets with GIADDR configured to 0 and containing option 82 are forwarded if the circuit is trusted. The default value is false. |
