DEMO FEATURE - NTPv4 Restrict is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see Fabric Engine and VOSS Feature Support Matrix.
Perform the following procedure to configure the NTP restrict capability for a specific IPv4 or IPv6 address(es), which means the switch permits NTP traffic flow from the specified IP addresses only. By default the NTP restrict capability is disabled.
You can configure a maximum of 128 NTP Restrict entries (IPv4 or IPv6 addresses).
0.0.0.0/0 or ::/0 NTP restrict entries are equivalent to no NTP restrict rules configured.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ntp restrict 192.0.0.0
Switch:1(config)#show ntp restrict
NTP Restrict Information
TYPE ADDRESS MASK/PREFIX LEN
IPv4 192.0.0.0 23
The following table defines parameters for the ntp restrict command:
Variable |
Value |
WORD<0-255> |
Specifies the IPv4 or IPv6 address.
Note:
You can configure a maximum of 128 IPv4 and IPv6 addresses in the NTP restrict list. |
