This procedure does not apply to VSP 8600 Series and XA1400 Series.Perform this procedure to configure a global IS-IS Level 1 metric for ports that operate in Auto-sense mode.
For the command to take effect, at least one adjacency must be formed through Auto-sense.
The following table defines parameters for the auto-sense isis l1-metric command.
Variable | Value |
<1-16777215> | Configures a static Level 1 metric for the Auto-sense ports. The higher the value, then the lower the cost for a route. The default value is 10. |
auto | Enable auto if you want the network route determined by summing the lowest value metrics, which are inversely proportional to port speed. The faster port speed is the lowest cost and the preferred route for all Auto-sense ports. |
