DEMO FEATURE - NTPv4 Master Mode is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see Fabric Engine and VOSS Feature Support Matrix.
You can use the following procedure to globally enable NTP.
For the VSP 8600 Series, you can configure the NTP version.
You can also enable master mode on the NTP server configured on the switch. When the master mode is configured, peers can synchronize themselves with the local clock when the NTP server loses synchronization or if an external NTP source is not reachable.
You must globally disable NTP before you change the version.
NTPv3 supports IPv4 addresses.
NTPv4 supports both IPv4 and IPv6 addresses.
Use data in the following table to use the Globals tab.
NTP Client section:
Name |
Description |
Enable |
Enables the client NTP server. By default, NTP is disabled. |
Interval Note:
Exception: NTPv3 is only supported on VSP 8600 Series. |
VSP 8600 Series: Specifies the time interval between successive NTP updates in minutes. The default values are:
VOSS switches: Specifies the time interval between successive NTP updates as a power of 2 in seconds. The default value for NTPv4 is 2 to the power of 8 seconds. |
Note:
Exception: only supported on VSP 8600 Series. Version |
Configures the NTP version. The default is NTPv3. |
NTP Master section:
Name |
Description |
Enable |
Enables master mode for the configured NTP server. The default value is disabled. |
Stratum |
Specifies the stratum for the master NTP server. The default value is 10. Note:
If a better stratum is available, it is preferred over what is configured. |
