Perform this procedure to view or modify the Auto-sense configuration on one or more ports. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
This procedure does not apply to VSP 8600 Series and XA1400 Series.Procedure
- Select AutoSense.
- Select the Port AutoSense tab.
- To change the Auto-sense state on a port, select a new value for AutoSense in the appropriate row for the port.
- Optional: If you disable Auto-sense on a port, select true for AutoSenseKeepAutoConfig to retain the configuration that the system applies dynamically.
- Select Apply.
Port AutoSense Field Descriptions
Use the data in the following table to use the Port AutoSense tab.
Name | Description |
Index |
Displays the index of the port, written in the slot/port[/sub-port] format. |
AutoSense |
Enables or disables Auto-sense on the specific port. The default value is disabled for existing configurations but enabled for new Zero Touch Fabric Configuration deployments. |
AutoSenseKeepAutoConfig |
Retains the Auto-sense configuration if you disable Auto-sense on the port. The dynamic configuration becomes a manual configuration and is visible in the show running-config output. |
AutoSenseState |
Displays the Auto-sense port state. |
AutoSenseDataIsid |
Specifies the Auto-sense data I-SID per port. The range is 0 to 16777215. |
