Querier Not Elected
If a Querier is not elected, use the following procedure to troubleshoot the issue.
Check whether IGMP snoop is enabled on the VLAN:
Switch:1>enable Switch:1#show ip igmp interface vlan ========================================================================================== Vlan Ip Igmp ========================================================================================== VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SNOOP SSM UPnP FAST FAST ID INTVL MAX MEMB SNOOP ENABLE ORIGIN SNOOP FILTER LEAVE LEAVE RESP QUERY ENABLE ENABLE Enable ENABLE PORTS ------------------------------------------------------------------------------------------ 1 125 100 2 2 10 false false RADIUS false false false 2 125 100 2 2 10 false false RADIUS false false false 3 125 100 2 2 10 false false RADIUS false false false 4 125 100 2 2 10 false false RADIUS false false false 5 125 100 2 2 10 false false RADIUS false false false 10 125 100 2 2 10 false false RADIUS false false false 100 125 100 2 2 10 false false RADIUS false false false 200 125 100 2 2 10 false false RADIUS false false false 300 125 100 2 2 10 false false RADIUS false false false 444 125 100 2 2 10 false false RADIUS false false false All 10 out of 10 Total Num of Igmp entries displayed VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP ID QUERIER QUERIER DOWNGRADE MODE HOST FILTER ENABLE ADDRESS VERSION TRACKING ADDRESS ------------------------------------------------------------------------------------------ 1 false 0.0.0.0 enable disable disable 239.255.255.250/32 2 false 0.0.0.0 enable disable disable 239.255.255.250/32 3 false 0.0.0.0 enable disable disable 239.255.255.250/32 4 false 0.0.0.0 enable disable disable 239.255.255.250/32 5 false 0.0.0.0 enable disable disable 239.255.255.250/32 10 false 0.0.0.0 enable disable disable 239.255.255.250/32 100 false 0.0.0.0 enable disable disable 239.255.255.250/32 200 false 0.0.0.0 enable disable disable 239.255.255.250/32 300 false 0.0.0.0 enable disable disable 239.255.255.250/32 444 false 0.0.0.0 enable disable disable 239.255.255.250/32 All 10 out of 10 Total Num of Igmp entries displayed
