The following table defines parameters for the ipsec esp command.
Variable Value
<aes128gcm16-sha256>
Specifies the AES cipher with a 128-bit encryption key and GCM block mode.
<aes256-sha256>
Specifies the AES cipher with a 256-bit encryption key and CBC block mode (for QAT performance mode).
<aes256gcm16-sha256>
Specifies the AES cipher with a 256-bit encryption key and GCM block mode.
