The following table defines parameters for the show ip igmp interface command.
 Variable  |
 Value  |
 gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 vlan <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 vrf WORD<1–16>  |
 Specifies the VRF by name.  |
 vrfids WORD<0–512>  |
 Specifies the VRF by VRF ID.  |
The following table defines parameters for the show ip igmp cache command.
                                                   Variable  |
                                                   Value  |
                                                   vrf WORD<1–16>  |
The following table defines parameters for the show ip igmp group command.
                                                   Variable  |
                                                   Value  |
                                                   count  |
                                                   Specifies the number of entries.  |
                                                   group {A.B.C.D}  |
                                                   Specifies the group address.  |
                                                   member-subnet {A.B.C.D/X}  |
                                                   Specifies the IP address and network mask.  |
                                                   vrf WORD<1–16>  |
                                                   Displays the multicast route configuration for a particular VRF by name.  |
                                                   Displays the multicast route configuration for a particular VRF by VRF ID.  |
The following table defines parameters for the show ip igmp sender command.
                                                   Variable  |
                                                   Value  |
                                                   count  |
                                                   group {A.B.C.D}  |
                                                   vrf WORD<1–16>  |
