The following table defines parameters for the show isis lsdb command.
 Variable  |
 Value  |
 detail  |
 Displays detailed information about the IS-IS Link State database.  |
                                                   home  |
                                                   Displays the IS-IS LSDB information that the system configures in the home area.  |
 level {l1, l2, l12}  |
 Displays information on the IS-IS level. The IEEE 802.1aq standard currently only defines the use of one hierarchy, Level 1. Level 2 function is disabled.  |
 local  |
 Displays information on the local LSDB.  |
                                                   lspid<xxxx.xxxx.xxxx.xx-xx>  |
 Specifies information about the IS-IS Link State database by LSP ID.  |
                                                   remote  |
                                                   Displays the IS-IS LSDB information that the system configures in the remote area.  |
 sub-tlv <1–3>  |
 Specifies information about the IS-IS Link State database by sub-TLV.  |
 sysid <xxxx.xxxx.xxxx>  |
 Specifies information about the IS-IS Link State database by System ID.  |
 tlv <1–236>  |
 Specifies information about the IS-IS Link State database by TLV.  |
