Use this procedure to configure the EAP operational mode.
Configure the EAP operational mode:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol eap-oper-mode mhsa
The following table defines parameters for the eapol multihost eap-oper-mode command.
| Variable | Value |
| mhmv | Specifies the EAP operational mode as Mutiple Host Multiple VLAN. |
| mhsa | Specifies the EAP operational mode as Mutiple Host Single Authentication. |
