Perform the following procedure to display information about all IP interfaces configured on the device.
Show the IP interfaces and addresses on the device:
Switch:1>enable
Switch:1#show ip interface
                          IP Interface - GlobalRouter
INTERFACE    IP             NET            BCASTADDR  REASM    VLAN  BROUTER
             ADDRESS        MASK           FORMAT     MAXSIZE  ID    PORT
Port1/6      192.0.2.6        255.255.255.0  ones       1500     200   true
Vlan100      192.0.2.5        255.255.255.0  ones       1500     100   false
Vlan4000     198.51.100.21    255.255.255.0  ones       1500     4000  false
Use the data in the following table to show ip interface command.
| Variable | Value |
| gigabitethernet | Displays IP interface information for Gigabit Ethernet ports. |
| vrf | Displays interface information for a particular VRF. |
| vrfids | Displays interface information for particular VRF IDs. |
