This procedure only applies to VSP 8600 Series. For information about how to configure an IP address for a Segmented Management Instance, see Configure an IP Address for a Segmented Management Instance.
Configure the IP address for the management port so that you can remotely access the device using the management port. The management port runs on a dedicated VRF. As a best practice, redirect all commands that are run on the management port to its VRF.
The configured IP subnet has to be globally unique because the management protocols can go through in-band or out-of-band ports.
Configure the IP address for the management port:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface mgmtethernet mgmt
Switch:1(config-if)#ip address 192.0.2.31 255.255.255.0
Switch:1(config-if)#show interface mgmtethernet
                  Port Interface
PORT                      LINK  PORT         PHYSICAL   STATUS
NUM   INDEX DESCRIPTION   TRAP  LOCK   MTU   ADDRESS    ADMIN  OP
ERATE
mgmt   64    mgmtEthernet true  false  1522  192.0.2.31  up     up
Use the data in the following table to use the ip address command.
| Variable | Value |
| <A.B.C.D> <A.B.C.D> | Specifies the IP address followed by the subnet mask. |
