- Disable ECMP before you configure route preferences
Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. You must therefore change a prefix list or a routing protocol before you activate the protocols.
Configure IP route preferences to give preference to routes learned for a specific protocol. You must disable ECMP before you configure route preferences.
To configure route preferences for a VRF, access VRF Router Configuration mode, rather than Global Configuration mode.
Configure the route preference to SPBM Level 1 and confirm the configuration is correct.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip route preference protocol spbm-level1 7
Switch:1(config)#show ip route preference
                       IP Route Preference - GlobalRouter
PROTOCOL        DEFAULT    CONFIG
LOCAL           0          0
STATIC          5          5
SPBM_L1         7          7
OSPF_INTRA      20         20
OSPF_INTER      25         25
EBGP            45         45
RIP             100        100
OSPF_E1         120        120
OSPF_E2         125        125
IBGP            175        175
View the route preference configuration for a specific VRF, for example 444.
Switch:1>enable
Switch:1(config)#router vrf test
Switch:1(router-vrf)#show ip route preference vrf 444
                         IP Route Preference - VRF 444
LOCAL           0          0
STATIC          5          5
SPBM_L1         7          7
OSPF_INTRA      20         20
OSPF_INTER      25         25
EBGP            45         45
RIP             100        100
OSPF_E1         120        120
OSPF_E2         125        125
IBGP            175        175
Variable definitions
Use the data in the following table to use the ip route preference protocol command.
| Variable | Value |
| ebgp | Protocol type eBGP |
| ibgp | Protocol type iBGP |
| ospf-extern1 | Protocol type ospf-extern1 |
| ospf-extern2 | Protocol type ospf-extern2 |
| ospf-intra | Protocol type ospf-intra |
| ospf-inter | Protocol type ospf-inter |
| rip | Protocol type rip |
| spbm-level1 | Protocol type spbm-level1 |
| static | Protocol type static |
