Delete a dynamically learned route from the routing table if you do not want the switch to use the route. Exercise caution when you delete entries from the routing table.
Delete a dynamically learned route:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#no ip route 192.0.2.32 255.255.255.0 198.51.100.31 dynamic
Use the data in the following table to use the show ip route commands.
| Variable | Value |
| <A.B.C.D> | Specifies the IP address of the route to the network. |
| alternative | Displays the alternative routes. |
| count-summary | Displays a summary of the number of routes learned from each routing protocol for each VRF. |
| preference | Displays the route preference. |
| -s <A.B.C.D/X> | Indicates the IP address and subnet mask for which to display routes. |
| -s default | Indicates the default subnet. |
| static | Displays the static route information. |
| vrf WORD<1-16> | Displays the route for a particular VRF. |
| vrfids WORD<0-512> | Displays the route for a particular VRF number. |
| spbm-nh-as-mac | Displays the spbm route next hop as mac. |
Use the data in the following table to use the no ip route command.
| Variable | Value |
| <A.B.C.D> <A.B.C.D> <A.B.C.D> | Specifies the IP address, the subnet mask, and the next-hop IP address, respectively. |
| dynamic | Specifies that a dynamic route is to be deleted. |
| enable | Disables the route. |
| local-next-hop enable | Disables the local-next-hop option. |
| preference | Deletes the value of the route preference. |
| next-hop-vrf WORD<1-16> | Specifies the name of the next-hop VRF router. |
