Perform the following procedure to display the PoE power measurement. You can view the voltage, amperage, and wattage for every PoE port. PoE ports without a PD in use are measured as zeros.
enable
show poe-power-measurement
Switch:1#show poe-power-measurement
POE Port Measurement
PORT Volt(V) CURRENT (mA) POWER(Watt)
1/1 34.0 117 6.200
1/2 34.0 94 5.000
1/3 34.0 535 28.500
1/4 0.0 0 0.000
1/5 0.0 0 0.000
1/6 34.0 525 27.900
1/7 34.0 152 8.100
1/8 34.0 49 2.600
The PoE port measurement for all ports is displayed. The preceding output is a sample of the full output.
