Perform the following procedure to display the PoE status for each port. You can use this information to view the status, classification, watts, and priority for each PoE port.
enable
show poe-port-status
Switch:1#show poe-port-status
POE Port Status
ADMIN CURRENT LIMIT FAST PERPETUAL
PORT STATUS STATUS CLASSIFICATION (Watts) PRIORITY POE POE
Port mgmt does not support DTE power
1/1 Enable DeliveringPower Class0 98 Low Disable Disable
1/2 Enable DeliveringPower Class0 98 Low Disable Disable
1/3 Enable DeliveringPower Class0 98 High Disable Disable
1/4 Enable Searching Class0 98 Low Disable Disable
1/5 Enable Searching Class0 98 Low Disable Disable
1/6 Enable Searching Class0 98 Low Disable Disable
1/7 Enable Searching Class0 98 Low Disable Disable
1/8 Enable Searching Class0 98 Low Disable Disable
1/9 Enable Searching Class0 98 Low Disable Disable
1/10 Enable Searching Class0 98 Low Disable Disable
The PoE status of all ports is displayed. The preceding output is a sample of the full output.
