Product Notice: This section does not apply to XA1400 Series, VSP 8600 Series, or VSP 4450 Series (flex-uni ports).Keep in mind the following operational considerations when you use the Extreme-Dynamic-Client-Assignments Vendor Specific Attribute (VSA):
Extreme-Dynamic-Client-Assignments takes precedence over FA-VLAN-ISID, EGRESS-VLAN-ID, EGRESS-VLAN-Name, and RAD_ATTR_TUNNEL_PRI_GROUP_ID.
You cannot use this VSA to dynamically create VLANs on a DvR Leaf node.
The Extreme-Dynamic-Client-Assignments VSA does not support static configuration.
As with all Extensible Authentication Protocol (EAP) enhancements, the Extreme-Dynamic-Client-Assignments VSA is not supported on the MultiLink Trunk (MLT) and Split MultiLink Trunk (SMLT) ports.
