Important
Configure these attributes only if you require dynamic port priority.
Port priority (vendor-specific) attributes:
Vendor ID: value 562 (Nortel)
Vendor ID 1916 (Extreme) does not support port priority.
Attribute Number: value 1, Port Priority
Attribute Value: value 0 (zero) to 6 (this value indicates the port priority value assigned to the specified user)
The following list provides the switch Port Priority frame format:
vendor specific type = 26
length = 12
vendor-id = 562
string = vendor type = 1 + vendor length = 6 + attribute specific = priority
The following figure shows an example of the port priority frame format.
