Perform this procedure to configure IPsec source IP address, Local Area Network (LAN ) interface IP and gateway IP address, maximum transmission unit (MTU) value, and so on globally, on the Fabric IPsec Gateway Virtual Machine (VM).
You must perform this procedure only after the VM boots up.
Configuring global parameters on Fabric IPsec Gateway VM to configure an IPsec tunnel between two switches:Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> set global ipsec-tunnel-src-ip 192.0.2.10/24 FIGW> set global ipsec-tunnel-src-vlan 101 FIGW> set global lan-intf-ip 192.0.2.20/24 FIGW> set global lan-intf-vlan 30 FIGW> set global lan-intf-gw-ip 192.0.2.30 FIGW> set global fe-tunnel-src-ip 192.0.2.40 FIGW> set global wan-intf-gw-ip 192.0.2.50 FIGW> set global mtu 1950
The following table defines parameters for the set global command.
| Variable | Value |
| ipsec-tunnel-src-ip {A.B.C.D/X} | Specifies the source IP address and subnet mask for IPsec tunnel. |
| ipsec-tunnel-src-vlan <2-4059> | Specifies the VLAN ID in the range of 2 to 4059. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. By default, the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. |
| lan-intf-ip {A.B.C.D/X} | Specifies the IP address and subnet mask for Local Area Network (LAN) interface. |
| lan-intf-vlan <2-4059> | Specifies the VLAN ID in the range of 2 to 4059. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. By default, the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. |
| lan-intf-gw-ip {A.B.C.D} | Specifies the gateway IP address for LAN interface. |
| fe-tunnel-gw-ip {A.B.C.D} | Specifies the gateway IP address for Fabric Extend (FE) tunnel. |
| fe-tunnel-src-ip {A.B.C.D} | Specifies the source IP address for FE tunnel. |
| mtu <750-9000> | Specifies the Maximum Transmission Unit (MTU) value. Note:
                                     If an IPsec tunnel is not using the fragmentation and reassembly capabilities, the default MTU value is 1950. |
| wan-intf-gw-ip {A.B.C.D} | Specifies the Wide Area Network (WAN) interface gateway IP address. |
| virtual-reassembly-intf-ip {A.B.C.D/X} | Specifies the virtual-reassembly interface IP address and subnet
                                mask on the Fabric IPsec Gateway (VM). Note:
                                     You must configure the virtual reassembly interface IP address to use the fragmentation and reassembly service. |
| virtual-reassembly-intf-vlan <2-4059> | Specifies the VLAN ID in the range of 2 to 4059. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. By default, the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. |
| ipsec-disable | Disables IPsec operationally on all tunnels in the Fabric IPsec Gateway VM. |
| ipsec-log-level <-1-5> | Specifies the IPsec log levels on Fabric IPsec Gateway VM. Following are the three levels:
