Perform this procedure to ping an IP Address on the Fabric IPsec Gateway Virtual Machine (VM).
Pinging an IP Address on the VM.Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> ping 192.0.2.35
The following table defines parameters for the ping command.
| Variable | Value |
| {A.B.C.D} | Specifies the IP address. |
