This procedure does not apply to VSP 8600 Series.
Use this task to configure or view IPv6 address information for a Segmented Management Instance.
                    Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
- Select Mgmt Instance.
- Select Mgmt.
- Select the Ipv6Address tab.
- Select Insert.
- Select the Segmented Management Instance interface type.
- Type the address information.
- Select Insert.
Ipv6Address Field Descriptions
Use the data in the following table to use the Ipv6Address tab.
| Name | Description |
| InstanceId | Specifies the interface instance. |
| Address | Specifies the IPv6 address for the interface instance. Ensure that the management CLIP IP address does not fall into the range of a configured VLAN IP address range as this is not allowed. |
| PrefixLength | Specifies the prefix length for the IPv6 address. |
| AddrOrigin | Shows the IPv6 address origin. |
| IntfName | Shows the interface name. |
| DadStatus | Shows the IPv6 DAD status of the address. |
