This procedure does not apply to VSP 8600 Series.
Use this task to configure and view IPv4 address information for a Segmented Management Instance.
                    Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
                    If the DHCP client is configured for a Segmented Management Instance, you must manually disable the client. Configuring an IP address does not automatically disable the DHCP client.
- Select Mgmt Instance.
- Select Mgmt.
- Select the IpAddress tab.
- Select Insert.
- Select the Segmented Management Instance interface type.
- Type the address information.
- Select Insert.
IpAddress Field Descriptions
Use the data in the following table to use the IpAddress tab.
| Name | Description |
| InstanceId | Specifies the interface instance. |
| Address | Specifies IPv4 address for the interface instance. Ensure that the management CLIP IP address does not fall into the range of a configured VLAN IP address range as this is not allowed. |
| Mask | Specifies the subnet mask of the IP address. |
| AddrOrigin | Shows the IP address origin. |
| IntfName | Shows the interface name. |
