Use statistics to help you monitor OSPF performance on a VLAN. You can also graph statistics for all OSPF packets.
 - Click VLANs.
 - Select a VLAN.
 - Click IP.
 - Click the OSPF tab.
 - Click Graph.
 - Select one or more values.
 - Click the type of graph.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
 Name  |
 Description  |
 VersionMismatches  |
 Indicates the number of version mismatches received by this interface.  |
 AreaMismatches  |
 Indicates the number of area mismatches received by this interface.  |
 AuthTypeMismatches  |
 Indicates the number of AuthType mismatches received by this interface.  |
 AuthFailures  |
 Indicates the number of authentication failures.  |
 NetMaskMistmatches  |
 Indicates the number of net mask mismatches received by this interface.  |
 HelloIntervalMismatches  |
 Indicates the number of hello interval mismatches received by this interface.  |
 DeadIntervalMismatches  |
 Indicates the number of dead interval mismatches received by this interface.  |
 OptionMismatches  |
 Indicates the number of options mismatches received by this interface.  |
 RxHellos  |
 Indicates the number of hello packets received by this interface.  |
 RxDBDescrs  |
 Indicates the number of database descriptor packets received by this interface.  |
 RxLSUpdates  |
 Indicate the number of Link state update packets received by this interface.  |
 RxLsReqs  |
 Indicates the number of Link state request packets received by this interface.  |
 RxLSAcks  |
 Indicates the number of Link state acknowledge packets received by this interface.  |
 TxHellos  |
 Indicates the number of hello packets transmitted by this interface.  |
 TxDBDescrs  |
 Indicates the number of database descriptor packets transmitted by this interface.  |
 TxLSUpdates  |
 Indicate the number of Link state update packets transmitted by this interface.  |
 TxLSReqs  |
 Indicates the number of Link state request packets transmitted by this interface.  |
 TxLSAcks  |
 Indicates the number of Link state acknowledge packets transmitted by this interface.  |
