View graphs for OSPF on a VLAN. The graph formats available are: line chart, area chart, bar chart, and pie chart.
OSPF must be enabled.
OSPF graph field descriptions
Use the data in the following table to use the OSPF graph tab.
 Name  |
 Description  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the OSPF-Graph tab.  |
 Average/sec  |
 Displays the average value for each second.  |
 Minimum/sec  |
 Displays the minimum value for each second.  |
 Maximum/sec  |
 Displays the maximum value for each second.  |
 LastVal/sec  |
 Displays the last value for each second.  |
 VersionMismatches  |
 Displays the number version mismatches received by this interface.  |
 AreaMismatches  |
 Displays the number area mismatches received by this interface.  |
 AuthTypeMismatches  |
 Displays the number AuthType mismatches received by this interface.  |
 AuthFailures  |
 Displays the number Authentication failures.  |
 NetMaskMismatches  |
 Displays the number net mask mismatches received by this interface.  |
 HelloIntervalMismatches  |
 Displays the number hello interval mismatches received by this interface.  |
 DeadIntervalMismatches  |
 Displays the number dead interval mismatches received by this interface.  |
 OptionMismatches  |
 Displays the number options mismatches received by this interface.  |
 RxHellos  |
 Displays the number hello packets received by this interface.  |
 RxDBDescrs  |
 Displays the number database descriptor packets received by this interface.  |
 RxLSUpdates  |
 Displays the number Link state update packets received by this interface.  |
 RxLSReqs  |
 Displays the number Link state request packets received by this interface.  |
 RxLSAcks  |
 Displays the number Link state acknowledge packets received by this interface.  |
 TxHellos  |
 Displays the number hello packets transmitted by this interface.  |
 TxDBDescrs  |
 Displays the number database descriptor packets transmitted by this interface.  |
 TxLSUpdates  |
 Displays the number Link state update packets transmitted by this interface.  |
 TxLSReqs  |
 Displays the number Link state request packets transmitted by this interface.  |
 TxLSAcks  |
 Displays the number Link state acknowledge packets transmitted by this interface.  |
