BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
- Select IPv6 BFD.
- Select Insert.
- In the Interface field, select either Port or Vlan and select an interface.
- In the NextHop field, type the IPv6 address of the next hop of the BFD session.
- Optional: In the VrfId field, type the ID of the VRF associated with the BFD session.
IPv6 BFD Static Route Field Descriptions
Use the data in the following table to use the Static Route tab.
| Name | Description |
Interface |
Specifies either a port or VLAN interface. |
NextHop |
Specifies the IPv4 address of the next hop of the BFD session. |
VrfId |
Specifies the ID of the VRF associated with the BFD session. |
VrfName |
Specifies the name of the VRF associated with the BFD session. |
