BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
- Select BFD.
- Select the Performance counters tab.
BFDPerformance Counters Field Descriptions
Use the data in the following table to use the Performance counters tab.
| Name | Description |
PktIn |
Specifies the total number of BFD messages received for this BFD session. |
PktOut |
Specifies the total number of BFD messages sent for this BFD session. |
